Can anybody speak from experience and tell me how much boost my 331/paxton novi 2000 combo will make? Even guesses are welcome. I've come to the conclusion my extra cubes and airflow will make less boost than the advertised 8-10 psi. Here's the combo:
331 with 9.4:1 compression (don't ask how, just trust me here on the comp.)
cobra upper and lower intakes (stock, but lower will be ported)
AFR 185 heads
I assume that 8-10 psi is based on a stock 95 302. I like the idea of less boost, as I'm still on a two bolt block. The block and rotating assembly are well prepared to push the limits of said block, so I'd like to get to about 500 crankshaft hp for now, until I get a 4 bolt block and pulley it up to 91 octane limits. I don't have any hp numbers for the combo as is, but the blower's going on in a few weeks when everything's completely ready. It'll be going straight to Dallas Mustang soon thereafter for a good tune. I'm not sure if the pulley that came with it will get me to 500hp if the boost falls off dramatically.
other questions:
It came with no charge cooling system, will I be missing hp, safety, or both?
Does anybodyy have any experience with the methanol kits?
Are they as good as advertised?
Do I really need charge cooling at boost levels from 5-10 if I don't want to make more than 500hp?
AFR 185 heads
other questions:
