  • 1994 - 1995 Specific Tech
how much hp?
  • Thread starter Thread starter shelbe67
  • Start date Start date Apr 6, 2006
shelbe67
309
Apr 6, 2006
  • Apr 6, 2006
I was wondering how much hp do you guys think that I will make with this combo? its a 347 stroker with vic jr heads, comp cams 282hr, 1.6roller rockers , 80mm mass air,42lbs injectors, track heat intake, mac long tubes, 75mm tbody, a 5 speed, and 373 gears how much at the tire do you think that I will make?
shelbe67
309
Apr 7, 2006
  • Apr 7, 2006
anyone?
GRGT1994
1,034
  • Apr 7, 2006
4?
shelbe67
309
Apr 7, 2006
  • Apr 7, 2006
thats it huh? what if I put my blower back on?
GRGT1994
1,034
  • Apr 8, 2006
5?
1994Vib.RedGT
585
Denver, CO
Apr 9, 2006
  • Apr 9, 2006
300 rwhp? thats my estimate
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 9, 2006
  • Apr 9, 2006
That should do around 375rwhp. What compression? Is this the combo you have or are you just thinking about building it? If not, i'll help you make more with better parts
shelbe67
309
Apr 9, 2006
  • Apr 9, 2006
I appreciate it grn92 I have these parts I bought a short block from a buddy that wasjust done he did forged crank rods and pistons it has the compcams xe282hr cam in it and I have2 set of heads that I can useI have box stock vic jrs and I have a set of fully ported and polished performer heads that I am thinking about using cause they flow more then the vics and I canstill use my emissions with them. what would you change to get more hp? I have flat top pistons in the block now he told me it has 10.5 to 1 compression but according to my desktop dyno it has 11:1. I just want the hp that my car had with the charger and heads without having to worry about blowing it up I would like 450 to the wheels if thats possible
shelbe67
309
Apr 11, 2006
  • Apr 11, 2006
still there grn92?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 11, 2006
#10
  • Apr 11, 2006
  • #10
shelbe67 said:
still there grn92?
Yo..
I would use the victor jr's hands down. A old school set of performer heads just don't compare. You will need to change the valve springs though.
I would use a holley manifold for this application. If you had steeper gears, i'd recommend a victor or a tfs R. I also recommend a custom cam, but that comp 282 will probably make good power.
Let an engine builder calculate your compression given your EXACT specs. Head cc, piston cc, deck height, gasket thickness ect. Rick 91GT on here might be able to help.
Check this link to give you an idea what victor jr's can do in a n/a pump gas 347 in a 94GT http://www.fordmuscle.com/archives/2005/02/YellowFever/
shelbe67
309
Apr 11, 2006
#11
  • Apr 11, 2006
  • #11
you wooulddo the vics even though my other heads should flow more? that car is awesome I hope that I can runthose numbers when I am done. what about thecomputer? what should I do? I have a pms for now
shelbe67
309
Apr 11, 2006
#12
  • Apr 11, 2006
  • #12
What about emissions? that was another concern I need to at least pass a visual well you know you are from ny
shelbe67
309
Apr 11, 2006
#13
  • Apr 11, 2006
  • #13
thanks greenfor your input
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 12, 2006
#14
  • Apr 12, 2006
  • #14
Keep the PMS, its an awesome unit. I run one in my sled.
Victor jr's hands down over your performers! Unless you flowed each head at the same time on the SAME bench, you can not compare flow numbers.
As far as emissions goes, victor jr's don't have any smog ports but the smog tech probably won't even notice. Most shops will test anything and if it passes, you're good to go. Or do an under the table inspection, cost a few bicks more but you don't need to worry about passing then
Fwiw, my friends stock 90GT with LT's and an o/r H pipe passes NYS emissions just fine on the sniffer.
shelbe67
309
Apr 12, 2006
#15
  • Apr 12, 2006
  • #15
does he still have his egr and smog pump still? thats amazing!I wanted to at least keep high flow cats on the car I heard that the cops have been checking so to me its not worth the ticket you know?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 12, 2006
#16
  • Apr 12, 2006
  • #16
Smog pump is gone, but egr is still there.
I just hate the sound of a catted pipe so I only run offroad Cops shouldn't bother you unless you're being a dick.
shelbe67
309
Apr 13, 2006
#17
  • Apr 13, 2006
  • #17
hes not getting a cel without the egr its very tempting lol what gears would be better then? 4.10? or 4.30? thats if I switch the intake, also 1 3/4 inch headers would help? whatshould I be pushing then? I really just dont wanna put my charger back on I want to have some sort of reliabilty without worrying bought popping headgasket again
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
