How much is to much??
GrandeStang73
93
VA
Got bored and took my motor and trans out. Then took the hood and fender and basically the front clip off. Not liking what im seeing. I'm probably looking at a new radiator support, entirly new inner fender aprons, and new shot gun rails. Is this worth saving?? If so, wheres the best place to get the metal for a decent price? Thanks a bunch as usual fellas! :SNSign:
Does the car have some sort of symbolic meaning to you? If so yes.
I'm replacing my front aprons, front crossmember, radiator support, floor boards, some of the trunk area. I don't think it's too much, because I had the choice of cutting my losses and finding another vehicle and swapping my drivetrain into that car, but I saw it as a hassle and the potentional of having something else wrong with that car, I'd see myself back to ground zero. I'd rather fix it the first time.
I did the sheetmetal under the battery (inner apron, radiator support, fron crossmember, inner and outer passenger side frame extension) a few years ago. It's not that big of a job, just level the car on jackstands before you start and be careful.
Is this for a 73 Grande? Is the damage due to rust or an accident?
If it is a 73Grande the amount of work you are describing is just not worth it. You can buy very good driving examples of that model for $6-8K all day long.
I don't know if the pieces you need are being reproduced. You might have to buy a parts car to get them.
