How much of a PITA are LCA's to install?
Blackie Lawless
You're just jealous because the voices only talk t
Naples, FL
If you had access to a lift: On a scale of 1 to 9, 1 being the easiest, 10 the hardest, how would you rate an LCA install?
I've had a set of Pro3i LCA's sitting in my garage for some time now and figure I might as well.
With a lift, you'll want a trans or screw jack to act as another set of hands, but other than that, it's a breeze!
Just did mine last weekend. Took my time and used hand tools. 2 hours, if that.
what's so hard about the sway bar? 4 bolts, and you take it off, or am I just lucky?
for some reason, I can't take my stock lcas out. there's some sort of benevolant force keeping the mother****ers in :mad:.
I thought the swaybar was pretty easy too.
I had a little of an issue with my stock LCA's.. just get a hammer or something and beat those bastards out :D
BFH FTMFW! :D
I couldn't even get the bolts out. there's a lot of lateral pressure on them for some reason. ill figure it out one day.
I've been reading that people are getting wheep hop with aftermarket lcas and removed quads. :shrug:
