How to change oil on Manual Transmission ?
today I am changing my mt oil with royal purple syncromax. i bought 4 qt from summitracing, I pour in all 4 qt and when I take out top drain plug to see if it's full but cannot touch oil and not over fill. Oil is not comming out of the top drain plug help. How many qts I need ? help asap Please.
thanks in adavance
lvmustanggt said:
thank god one car shop here in vegas had royal purple, I went and bought one more . after 4.5 qt it's full and over filling yayyyyyyy
its recommended to underfill the tranny. ive heard it actually reduces drag between shifts
Did you jack the car up at an angle when you did this? If the tranny is tilted to the left (as in you jacked up the car on the right) its gonna be overfilled.
I've found a way to refill the tranny (and diff) that has worked for me: Take a plastic or stiff silicone hose, (about 1/4" dia. 2' long) cut the top of the fill spout on the jug a little smaller than the hose, force the hose through, letting the hose just reach the bottom of the jug when you screw in back on. presto, instant squirt jug. squeezing the jug forces the lube up though the hose. it's a little slow, helps to warm up the lube 1st. but has worked mess free for me.:nice: never tried filling one from the top, may be easier?:shrug: I hate Iffy lube places. the only times I've ever used them, I've had my drain plugs cross threaded, i've had them only put in about 3qt into a 5.0:eek: I've had the filter so tight i had to crush it flat to remove it. unless i have broken arms I always do fluid changes myself. I don't trust em anymore.
Someone should do a write-up on how to change the fluid, with pics. This question seems to be asked pretty often. It's fairly simple, but if there were a sticky, obviously people could just go to the FAQ sticky and look it up. I'd do it if I had a digital cam that was worth a crap. A coolant flush write-up would be a good idea too.
