Yeah the 2x4 thing sounds a little scary. I think I will try the ratchet straps tomorrow. I will let you guys know how that goes. Though wouldn’t that be risky too on jacks? The car feels solid but that’s how it always goes until it’s too late… now I have to find something strong enough for it to hold on to……Ratchet strap should work. Bolt the one side up until the ball socket starts to seat. Wrap it around the transmission and both pipes. It shouldn't take a whole bunch of pressure to get the pipe to flex enough to get the ball flange to line up. Easier on a 5 speed where there's no dip stick in the way.
You could also put a jack under the pipe and use a 2x4 to pry the pipe over to line up. The heat from driving the car should take the stress out of the pipe.
The 2x4 thing is scary on Jack stands. Pushing towards one side could make the car fall if they aren't stable or positioned correctly.
If the exhaust angle is off a small amount it could cause it to be off way more at the tail pipes. They are right about that.
I'm late to this party but wanted " in " on the brain storming debacle.
Thanks for your input
