I took off the kick panel, and there are 3 plugs right in front of the PCM. do these have to be unplugged and out of the way for the PCM to come out? The instructions that came with the twEECer suck hard. What does the actual twEECer plug into? I see an aluminum box, with some sort of module plugged into it, then the module has the 60pin harness coming off it. I'm kinda lost here.
I got it installed, but now it doesn't run. I pulled the PCM out, and the tweecer was only half on (might have happened as I pulled out the PCM). Then I took the tweecer off, and it had a bunch of that goo still on the circuit board.
