I.E. radiator and under the front and rear fenders. This is all new metal and no holes. Do i have to make a zillion tiny holes insert staple and bend back? or just glue the sobs on. Thanks. 65 stang.
Do the staples on the rad support. You'll need a 1/16" drill, and a longnose pliers. Curve the ends of the staples slightly before you push them in. Push them in, and bend the ends with the pliers. When you have recreated the OEM look, you'll be glad you did.
As for the splash shields, the good ones with the rubber already installed are almost the same price as the bare ones with the rubber in a bag. Buy them.
well the car came with the o.e. steel units already under the fenders. so i got just the rubber for them. i can take em off. and install the rubber, then put em back on.
I use hex head self drilling screws to attach the rubber to the inner fender pieces. I've done about 6 sets this way. Hold good and can't really see them anyway.
