most of what you need to know for reduction.
http://users.adelphia.net/~mustang-92/Weight Reduction.htm
there are a bunch of miscelanious metal 1 pound brackets on the car you will find as you work.
I figure ill cut the pipe un-screw the bolts and try to put the plugs in i just got ( like the ones in the pic above) if i cant get them in cause of the build up Ill flip the blocks. In case i resort to fliping the block do i need to use any kind of sealent to seal the block the the head, so i dont get any kind of leaks? Thanks again!
