how to tell if you have underdrive pulleys or not
Well I want to be able to tell if I have underdrive pulleys on my car or not, I found out the other day that my timings been advanced arready and theres a few mods on there arready and I was wondering if the previous owner arready covered it or not.
When I get a chance Ill post pics of all that but can anybody tell me off the top of there head what are some noticeable things.
Also would like to remove smog pump and do pulleys at the same time, anybody have a diagram or a page of what is needed to do both of them?
if you are not having charging or temp issues (sometimes a tell tale sign), i might find a bud with stock pulleys and compare. or measure yours and go to the parts store and ask to see a replacement stock pulley - compare the dimensions.
good luck.
What is the approximent diameter of the water pump and crank pullies....
If the crank pulley is around 5" it is stock, most aftermarket underdrives are around 2.75".
The water pump pulley is really a OVERDRIVE with the underdrive pulley set, it will be around 5.25" in diameter.
The A/C should not be effected that much, I would bet it is the amp your alt is putting out sinmce it will drop severely at idle with underdrives, or the A/C could be getting low on freon.
The a/c can definitely be affected by underdrives. Not only is the compressor turning 20-25% slower than it was before, the fan is also usually turning a bit slower as well, pulling less air across the condenser coil - which impacts a/c output at idle.
Very true they are about 25% less then stock. When I first got underdrives my motor was stock A/C and all, only issue I ever had at idle where it was notciable difference was a weak alt and a bad clutch fan that wasn't working properly cooling the rad and condenser.
MARK89NOTCH- The stock fan assembly and fan clutch is the best cooling set-up out, they do a better job then most electrics as long as they are in good working order.
Micheal do you have nay pics of the 5.0 in the volvo, I've seen you post any but I want to show some people. [email protected]
