how to test if ecu is fried?
stackz
1,352
james island, sc
ahhh, question #2 for the day.
swapped out the stock aode in my 95 gt vert with a 4R70W from a 96 explorer.
car ran when I took it apart for the swap. I did swap the TCC solenoid as told and got a chip for the computer. timing is on par as well. car wont start.
cant even really hear it try to misfire from gas in the cylinders....yeah it does crank over just fine.
can I hook my obd1 scanner up to it? just no clue how to test if the ecu is good or not??
Use a spark tester or spare plug. Set either on the plenum where you can see it from the cockpit.
I forgot to add earlier that the EEC's are robust - they dont often fail unless someone does something like a double-reverse polarity hook-up. They use heat-sink tech so that even if a signal wire shorts to ground, it comes back as a bad reference signal, rather than a positive-to-ground short.
got it figured out. I had a digital code reader hooked up to the test port and it never got past the "connecting to ecu" part so I started checking harness connectors and in doing so, realized I never hooked the module back up that's located on the radiator overflow bottle. :rolleyes:
hooked it up and the car fired right up. :rolleyes::nonono::rolleyes:
lol....duh...
