How to use 2 12ohm subs?
I have 2 10" Mtx subs that are each 12 ohms. I also have one mtx801d mono amp with two speaker outputs. Could i just wire each speaker into one output and get plenty of power to run them well? It puts out 800 watts rms at 2 ohms. Would that give me a 6ohm load and would it be safe for the amp?
If they are single voice coil (SVC) subs, the lowest ohm load the amp is going to see is 6 ohms which won't really give you much power since it runs max. @ 2 ohm.
If they are dual voice coil (DVC) subs, the lowest ohm load the amp is going to see is 3 ohms, which will give you pretty decent power for 10's.
i think single voice coil subs are all only 4 ohms, and dont think you can bring them down to 2 ohms because in ordor to get 2 ohm load you have to wire the 2 subs toghther, and then you would need a 2 ohm stable amplifier.
You can get SVC's in other ohm loads, although I have never personally seen a sub that was 12 ohms. But all companies make them in other ohm loads besides 4....generally they are 2, 4, and 8. Those are the most common ones.
