How too???
Beasty306GT
671
Oxford,Mass
Ok everyone i put the mustang in storage in my garage and i need to pull the gas tank to install a new one. What is the easiest way to do this theres barely any gas in it. Its an 89 gt is that matters...im gonna undercoat the bottom of the car also while i got the tank out...any pictures or tips would help :SNSign:
Also it has a 94 feul sending unit is the plug the same or do i have to transfer mine into the new tank
Get the back of the car as high as you can get it. Remove the 4 bolt around the filler neck, remove the 1 bolt that hold on the filler pipe support, spray some WD40 around the filler pipe and work it out from the top, gas door. After thats out then you upbolt the take at the front of the straps, lower the tank being careful not to drop it, remove the hose to the filter and the return line. The retunr line uses different clips than the filter. I got new ones from the dealer, 2 or 3 bucks. Remove the electrical connections and lower the tank with a jack.
gas tank
Good instructions, a few more points:
1. The less gas in the tank the better!
2. Go slow with the filler pipe, the reinstall is trickier than the removal
3. The tank is not flat all the way across on the bottom so balancing it on the jack is tricky, again go slow as you lower it. Have someone help if you can
4. If you plan on a new fuel pump in the future, now's the time
5. Also good time to replace fuel filter
6. If you use a piece of wood on the jack for balance, make sure its not covering either of the tank straps.
7. Get a small bucket to catch the gas that will spill, shouldn't be much.
Thanx guys...thats what i figured...the new tank has a new pump in it already...dont know when its commin out but i got all winter....the rearend i gotta drop out too....any pointers for the rearend??? any step by step instructions???
So, you have an 89 tank and connections with a 94 fuel sending Unit? I always thought they were different after 93 and would not work in earlier ones without modification but I could be totally wrong. Also, are you getting a new tank or re-using the current one? Your post sounds like you are swapping stuff into a new tank or something.
