hurst
  • Thread starter Thread starter pconway
  • Start date Start date May 7, 2005
P
pconway
72
wtby, ct
May 7, 2005
  • May 7, 2005
just put a hurst in my car. and well there in=s this metal bezel with like a rubber boot. and it is hard ass hell the get back over the shifter. what should i do??
HISSIN50
34
129
May 8, 2005
  • May 8, 2005
i would get a spare one from the junkyard that you can hack up. that boot is for noise and heat suppression - you will notice its omission.
good luck.
Saleen0679
876
24
49
Yakima, WA
May 8, 2005
  • May 8, 2005
What specifically is the problem? The Hurst shifter installs that I have done went smooth except when I tried to put the metal frame boot on without removing the center console. It worked one time, but not another. Otherwise it should slip over the shifter and bolt down.
P
pconway
72
wtby, ct
May 8, 2005
  • May 8, 2005
its hard to push down so its level on whatever i got to bolt it to and well i came backto edit something and i forgot what i was gonna say so nvm. will dirt get in the shifter??
Saleen0679
876
24
49
Yakima, WA
May 8, 2005
  • May 8, 2005
Dumb question that I gotta ask. Did you remove the stick before trying to slip the boot/bracket back on so that it doesn't catch on the stick mounting bolts?
If not you will have to work the boot past those bolts.
You shouldn't get dirt into the shifter without the boot/bracket if you installed the boot that Hurst supplies to wrap around the base of the shifter. The boot/bracket that bolts to the transmission tunnel keeps crap from coming into the car and also works as a noise isolator.
P
pconway
72
wtby, ct
May 8, 2005
  • May 8, 2005
i got the shifter in its pretty sick lookin.
Saleen0679
876
24
49
Yakima, WA
May 8, 2005
  • May 8, 2005
Glad to hear it.
You'll find it shifts so much better than the stock unit.
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
