I tried a search guys. I can not turn my TPS sensor and get the screws in where I want my idle. I'm ideling at 600rpm with the screws lined up and the car is just dying right out. If I feather the gas pedal it is fine.
Is there any kind of trick. There's not much adjustment from the TPS to the screws taps. Well I have to go buy a new TPS anyways cause I stripped the cheap plastic inside retainer part.
I was trying to turn the screw with the spring under the TB. It's connected to the throttle linkage. I thought this would work but appartently not. What gives?
