I can't find....
I have longtubes on my 95' stang. I used a Mac Prochamber, which yields 8 more hp on they dyno over a Bassany X-pipe. I had to bend one of the pipes a little with a pipe-bender to make it fit my BBK headers, but it should bolt right up to a set of Mac headers.
Kurt
Dr. Gas sucks ass. There product consistently scores lower performance numbers on they dyno when tested against their competitors, even though a Dr. Gas exhaust cost $100 more.
Kurt
SN95StangMan said:
I think Dr. Gas is your only choice for an X-pipe that will fit longtubes
Damn. I haven't heard a lot about Dr. Gas but what I have heard was positive. Any idea as to the quality of the fit and finish? What about sound and performance?
Kurt, I don't really like the sound of a ProChamber. That is just me though. Plus, I want to do something a little different and I know a lot of people run ProChambers.
No no. If your car doesn't sound right, it's not because of the exhaust. You just have to put more motor behind it. Put a stout cam in it, and it will sound just fine. However, if that's the way you feel, I know that Bassani and BBK both make intermediaries for there longtubes. I know that Bassany makes an X-pipe.
Kurt
Kurt
I never said my car sounded bad in the first place.
As far as I know, Bassini only makes LT headers for Foxes and only makes the x-pipe for the LTs for the Foxes. As for Dr. Gas x-pipes, I love mine. Combined with my LT headers and straight-through mufflers, it makes the car scream at the upper rpms. I constantly get compliments that I have the best sounding Mustang that people have ever heard. I've never heard of Dr. Gas dynoing lower than other brands :shrug: .
As for fit and finish, it comes in peices so its basically up to your welder. My mechanic did a great job, I have more ground clearance with my X-pipe than I did with my stock h-pipe. Overall Im very satisfied with my Dr. Gas, and if theyre ever an option again, I know who Ill be going with :nice: .
I have an article in 5.0 Mustang with an exhaust intermediary dyno test showing it. I believe I have an MM&FF article showing the same results. You know how these magazines are. They repeat the same tech articles once a year. January = blower tech, February = exhaust tech, March = cylinder head tech, etc, etc.
Kurt
This is going to take some article hunting. The first article I found was in a 5.0 Mustang magazine from November 1999. It compares a no cat H-pipe to a BBK prototype X-pipe. Peak horsepower increased from 247 to 252. Peak torque increased from 281 to 287. RPM ranges were the same for both.
Kurt
OK, I found the article I was looking for. It's called the "X-files" and it was in the May 2000 issue of 5.0 Mustang.
Stock: HP = 247.6 TQ = 294.2
Bassani: HP = 276.6 TQ = 325.2
BBK Performance: HP = 277.1 TQ = 309.3
Dr Gas HP = 275.3 TQ = 302.7
Hedman hedders X-treme HP = 282.9 TQ = 322.7
MAC Prochamber: HP = 284.8 TQ = 322.7
The Prochamber came out ahead.
Kurt
The car they tested with had an E303 cam, Cobra upper/lower, 24-lb/hr injectors, 65mm throttle body, and "a set of short-tube headers and a good after-cat exhaust system." Unfortunately they were not brand specific. The stock numbers were generated using the 4-cat h-pipe that came with the car.
Kurt
I e-mailed Bassani and they DO NOT make an X-pipe for LT's. :notnice: It looks like I will be going with the Dr. Gas.
