The links in my first post would have helped you with some of this stuff.
The OEM fan is a two-speed unit.
The WOT relay is in the CCRM. The power to the AC clutch passes through the N.C. and common terminals at rest. The only time the relay is active is if you're at WOT.
This sounds exactly like the problem I'm having now! Car just started doing this same thing today! It usually never went past O on the NORMAL and all day today it was between M and A and sometimes on A. Coolant is good, thermostat opens and fan still kicks on. But I didn't even know that it was a two speed fan. The fan never kicked on till it hit the A. Could that mean that the low speed is not workin?
I'll have to check that out. Gonna get a new cap and thermostat for it here in the next couple days and see what that does.
