I lost my MC on my 88 Mustang. I have the 73MM calipers up front. I plan on converting to the MarkVII rear disc over the winter. So I decieded to get the SVO MC. Now my question is about the lines that run from my MC to the PV. Will I have to bend and cut my own lines or do they make them pre-made. Cause I'm assuming I'm going to need Standard threads on one side and Metric threads on the other so I can fit them in my stock PV and new SVO master cylinder. I'd be cool if a company made these lines just for my application. If you have any idea's about what you would recommend I do that would be awesome. I've never bent or cut brake lines before.
Should I get an adjustable PV? Would it be needed while I still use the rear drums for now? And will I defientely need one after I do the rear disc's? I'm trying to get this done cheaply but I also want to be safe.
Thanks for your time. Ryan
