I need some help
forbesfamily1
I have a question for the forum..
I bought a 1997 mustang gt 2v last month.. I wanted to awaken the inner beast in her. I was doing some research on comp cams XE270AH. Definitely will wake her up. My question is will it work well with pi intake or is there some sort of modification in store in the future????
  • Sponsors(?)
08GT500
858
133
53
49
Massachusetts
Hi,
Congrats’s on the new Pony! The PI upgrade actually reaps 90% of its benefits by the intake alone, giving it to 45HP+ kick to 260Hp from the 215BHP it had come with.
It’ll work with the PI intake, but you’re looking at the exhaust being non-restrictive, an intake system that will do the same.
The 270 cam(S) will wake it up, but you need support it with other mods. There’s many other Cams that may suit you better for usable torque/Hp on the street. What are your goals, this a DD, lot of highway driving, some Strip, etc?
Building it equally will give you the optimal gains, and drivability. Tuning will get it running at its best. Just how much do you want to wake it up?.
Have a budget?
Best!
-John
Thread starter Similar threads Forum Replies Date
D Suspension Griggs rear set up on my 1991 GT, need help with set-up Fox 5.0 Mustang Tech 1
mustangpauly 351w swap need help will not idle Digital Self-tuning Forum 8
T Need help identifying casting numbers 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
ameration Need Help with new 5.0 Purchase 1994 - 1995 Specific Tech 6
J Need help with qurterhorse and running Digital Self-tuning Forum 1
L Electrical Need Help Fox 5.0 Mustang Tech 15
B Need some help cars not right SN95 V6 Mustang Tech 1
T need help deciding on what cam i should get for my mexican block 302 Fox 5.0 Mustang Tech 8
A Engine 87 EFI 5.0 to my 83 four eye need help with wiring Fox Engine Swaparoo 0
R Need help finding reverse switch on transmission Fox 5.0 Mustang Tech 5
S CARWASH WASHOUT NEED HELP PLEASE 1996 - 2004 SN95 Mustang -General/Talk- 3
C Need help troubleshooting p1233 code. SN95 4.6L Mustang Tech 2
7991LXnSHO VW OBD2 help needed. Other Auto Tech 0
8 Engine Need help Fox 5.0 Mustang Tech 6
B Engine 1990 5.0L Fox high rpm cutout and loud backfire - Need Help Fox 5.0 Mustang Tech 11
silverlx50 Engine Bringing Charcoal Canister Back, Need Help Fox 5.0 Mustang Tech 4
A Drivetrain I Need Some Flywheel help/knowledge please Fox 5.0 Mustang Tech 7
B Need Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
YadiStang 1969 mustang. Need help with door lock actuator rod 1965 - 1973 Classic Mustangs -General/Talk- 0
D Brake issues I need help figuring out what part to order 2005 - 2009 Specific Tech 1
M I need help sourcing/repairing a fender 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
D Progress Thread 2003 mustang gt Rebuild 1996 - 2004 SN95 Mustang -General/Talk- 10
S Electrical Need help with unidentified wire connector on 4 cylinder LX 2.3L (N/A & Turbo) Tech 3
W T5 rebuild - need help identifying parts Fox 5.0 Mustang Tech 12
Gman007 Need help with strut choice. SVT Tech Forum 8
markinms Engine Explorer Intake Swap Performance Issues - Need Help! Fox 5.0 Mustang Tech 10
S 2002 gt need help. 1996 - 2004 SN95 Mustang -General/Talk- 4
T Need help with throttle cable. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
T Engine Need help with 5.0 ho speed density build Fox 5.0 Mustang Tech 9
S 1995 Ford Mustang 3.8L V6 - Electrical Issues - Need Help! 1994 - 1995 Specific Tech 8
T Questions about power steering delete!! Need help!! 1996 - 2004 SN95 Mustang -General/Talk- 5
R need helpful tech help Fox 5.0 Mustang Tech 3
F Help needed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
D Need sct x4 users help please. Digital Self-tuning Forum 0
E I need help with my AC system 1996 - 2004 SN95 Mustang -General/Talk- 5
G Engine Need help with cooling system issue Fox 5.0 Mustang Tech 12
N Need Help w Heater Blower Failure 1994 - 1995 Specific Tech 13
Jetzv8 2014 Mustang radio not working. NEED HELP Mustang Sound & Shine All 0
A Suspension Fox steering rack leaking need help Fox 5.0 Mustang Tech 1
S PWM Fan controller - Need help/clarity on a purchase 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 32
F I need help Fox 5.0 Mustang Tech 1
lamrith New MSPnP2 in 94 Mustang, need help getting stable idle once warmed up. Digital Self-tuning Forum 1
W 347 Header Size and exhaust Diameter 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 51
Z I need help with pistons 1996 - 2004 SN95 Mustang -General/Talk- 1
trlps_ Need help, car wont rev up or drive 1996 - 2004 SN95 Mustang -General/Talk- 2
T Electrical Need help with A/C clutch cycling connector Fox 5.0 Mustang Tech 2
bmgstang Need help with tune high idle Digital Self-tuning Forum 7
S Engine Need help: heater hose routing for 92 2.3 liter 2.3L (N/A & Turbo) Tech 4
T First fox... she needs help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
C Engine Help diagnosing a whine at low gas pedal pressures - 1998gt SN95 4.6L Mustang Tech 2
