I ordered a ramchargers fan because the sn95 wouldnt fit. Right now I have just over 4" of space between the crank pulley and the radiator. Ramchargers says their fan is 3 3/8" thick so that should fit. My problem with the sn95 is that the fan motor was hitting the crank pulley. It was $80 + shipping, I got the one w/o the wire harness since I dont need that fancy harness and stuff.
Hopefully tonight I can get the new fmu fitting I need so I can cut the 90* one off since its loose and get the FMU mounted and installed. I wanna get the T rex in tonight too.
I just gotta tighten down the pump wires and hook up the + wire to the battery. Rick, you were right, the T rex is labeled + and -. I saw it after I put the wires on and luckily I guessed right and didn't have to switch them
