(I think) Timing chain issue... might explain dyno/starting/timing issues..
Hi there,
I had a problem with a balancer i bought a while back, the numbers on it were in the correct position for timing chain cover with the pointer on the passangers side but mine is on the drivers side. I had a reading similar to yours to get the motor to run close to good, stamped new numbers on it and started again.
Steve
Hi there,
Steve
Before you put the new #'s on, was your timing pointer pointing to 0 at TDC? My balancer has 3 sets of #'s, one of which matches up to my pointer at TDC. I would think this wouldn't be a problem if your pointer lines up with 0 but I guess theoretically just lining up at 0 doesn't mean they're right all around.
Capt Dan said:
It could if you were not hooking up your timing light to the #1 spark plug wire.
I am 100% sure I'm hooking up the light to the #1 wire (well, to the #1 spark plug, after working through some logic it'd probably be the #3 terminal on the distributor). Does that kill the theory automatically?
Say I connect the #1 spark plug wire (w/ light) to where the #3 terminal is (next one up, since 351w firing order is 1-3-7-2-6-5-4-8).
A spark would go to the #3 terminal and then to the #1 plug (and light) about 45 degrees early (1/8 a turn). While the distributor thinks you're firing the #3 50-55* BTDC early you're really just firing the #1 plug at about 5-10* BTDC. Hence why it runs decently at initial timing numbers that don't make sense.
Any flaws with this logic? Seems like its worth a shot...
Others will have to verify, but I think you are using the wrong firing order for the cam you are using. The correct firing order (based on threads i have read) I believe should be 1-5-4-2-6-3-7-8. Does the cam card list the firing order to use? You are using the XE274H cam, correct?
Pretty sure thats the 302 firing order, not the 351w. 351w and 5.0 HO are what i wrote, what you wrote is the old school 302/289 firing order.
fordmach... going CCW (unless my memory is even worse than I think it is...)
edit: got it all back together last night but the battery is dead, so it'll have to wait til today when we can charge it to mess with the spark plug wires
I think the 2 different part numbers reflect hydraulic roller and hydraulic flat tappet. I based on the part# in his sig, I believe he is using the flat tappet. Jegs has the firing order posted for this cam:
35-246-3 - Comp Cams 'Xtreme Energy' Hydraulic Flat Tappet Camshafts Details
Ford/Mercury 351ci/5.8L ''Windsor'' 1969-95 & 302ci/5.0L H.O. 1982-95
*Note: Firing Order 1-3-7-2-6-5-4-8
So it looks like he is using the correct firing order, just need to make sure it is in fact wired properly going counter clockwise. I have a feeling the root cause for this problem is very simple and will surprise all of us when found. Let's hope it's soon!
Comp doesn't list an XE274H roller cam.
I didn't know Jegs provided the firing order, but I checked the 35-246-3(351W) against the 31-246-3(smallblock) and they do indeed have different firing orders.
I have the 35-246-3.
We moved the spark plug wires over one (CCW) and then wrestled with it for about 2 hours, didn't make a whole lot of difference (other than a huge hassle trying to find where it ran again). We had to restab the distributor about 30 times... and when it finally ran (idled... really, really rough), the initial timing was... shock... 50 degrees or so :(
Guess I try reversing those wires within the distributor next...
Swapping a 500 edelbrock on friday just to see if that helps.
Did you ever verify that the avance isn't locked out on your distributor? What stop bushing and spring combo is installed?
I think we still have the stock/standard bushing & spring combo for now... wanted to get it timed before messing with that since right now its impossible to tell how much actual initial or total timing I'm running.
Have not verified the advance isn't locked out. Will do soon.
Swapped carbs (both rusty's holley and my brothers edel 500), didn't make any difference. Not that it makes a difference in the meantime, but I re-jetted my carb (71 primaries, 76 secondaries, up from 65/68). Floats weren't stuck, fwiw.
Haven't checked the distributor lockout yet. Plan on calling compcams and MSD today to see what they say.
