I want to get rid of my fruit jar
sa_andy
11
Hi,
I have a 66 with a 289, non power drum brakes, non power steering, automatic. I want to replace my single master cylinder with a later model dual master cylinder (for safety reasons). Some time in the future, I would like to add disk brakes, and perhaps add power to those disk brakes.
Is there a dual master cylinder that I could buy and install now on my non-power drum/drum setup, that would be applicable when I make the switch to disk, or even power-disk, sometime in the futer.
And is there anything else that I have to change? Thanks
if you are planning a swap to power brakes, do so now and change the m/c at the same time. you can use a disc/drum m/c on the power booster with an add on residual check valve(10 psi) on the disc side untill you swap to disc brakes at which time you remove the check valve.
sa_andy said:
Hi,
you are in luck! This fine fellow on the VMF just finished this changeover:
http://forums.vintage-mustang.com/f...917044&page=0&view=collapsed&sb=5&o=7&fpart=1
thanks for the info...
what mc should i buy? Maverick? Mustang? Something else? and what residual valve??
I'm new at this...sorry for all the questions
