iac off right now, HELP
SMRcalidiv
496
Sacramento, CA
ok i am cleaning my iac , and i just took it off 8:15 est, mon., literally right now, i ned to know what i need to know about cleaning it, is spraying carb cleaner sufficient? do i need to brush anything? i will in all likely hood buy a new one, this is temp. so just give me pointers please...how long for it to dry do you think, and how important is that?
Simple! What year is it?
Most likely it needs to be replaced if you are having trouble. Use intake cleaner that is safe for throttle bodies ONLY...nothing else. It was state that on the label. Spray the crap out of it. be liberal witht he cleaner. Keep spraying and shaking it out. Then let it sit for a few minutes and spray again. As far as I know you can put it on still wet, just get as much out as you can out.
Have more problems send me a PM with you phone # and i will call you.
yes just the the norm, start stall, hey again black, well i went to the store butthey didnt have any "throttle body" cleaner, just some b12 carb spray, will that work? cardinal said brake cleaner but, i dunno, is carb cleaner ok?
when i was at the dealer we used brake cleaner, mostly cause getting a bottle of throttle body or carb cleaner meant a walk over to parts dept. i used brake cleaner on my IAC and it fixed it for a few months. i wouldve just cleaned it again, but on a crown vic the IAC faces the firewall and its kinda of a PITA to get to so i got a new motorcraft one for $40
