ID This rear disc set-up
time only
461
Miami,FL
Hi, Get a chance to take the wheel of my car and shoot some pictures for some help in ID this brake set-up. It is suggested before it might come from a Thunderbird Turbocoupe and the quads mounting points will have to be moved,looking at it,seems to be still in the same stock locations,but the quad shock is almost flat to the ground ( The car is lower,don't know if thats what causing it ).
Thanks for any help
Kin.
txstang84 said:
nahh, the '93 Cobras were indeed 4 lug...the only 5 lug 'stangs were SVO's, and Saleens...
and the turbo coupe t-birds were also 4 lug (they shared alot of parts with the Mustang)
agreed on the turbo coupe. The only 93 cobra that was 5 lug was the R. I will make sure I look closer next time :D
They look like SN95 rear calipers bcause they basically are.
The bridge of the caliper is different, but the caliper is almost identical to the 38mm Varga caliper used on all SN95's
EVERY 94-04 Mustang uses the same rear calipers. GT CObra, MAch, V6 all the same caliper. Only the bridges are different.
I beleive the t-bird/93 cobra rear caliper is the same way
Thank you ! Everyone,I think it is almost 100 % match for a T-bird rear disc setup. I don't believe it is a aftermarket ( SSBC or even a Motorsport rear disc system ). I am the third owner of this car and it seems the last 2 owner never really put money into it. The radiator still have the stock factory clamp on it. It is a shame for it is a nice looking car.
