Ok boys here is the problem, when I start the car it idles fine, but when it gets up to operating temperature it surges ones or twice and then cuts off, which is becoming a big pain every time I stop at a stop sign or light. Driving down the road it does great pulls, strong as hell, and you can’t tell anything is wrong, but if let off the gas and the RPM’s fall to quick it dies. You can keep it running, but you have to keep it revd up at about 1200 RPM’s. So, any ideas? All help and input will be appreciated.
Hear is what I have done. Cleaned the AIT,MAF, checked the plugs, checked for vacuum leaks.
Hear is my setup.
30lb injectors
Pro-m mas air
Adjustable fuel pressure regulator
2x gt28rs turbo’s
2x 50mm BOV
12x4x36 intercooler
Flow master 40’s
Motor stock
AODE to T5 conversion
453 rwhp @ 10lb of boost
504 ft lb of torque 1994 mustang
Hear is my setup.
30lb injectors
Pro-m mas air
2x gt28rs turbo’s
2x 50mm BOV
12x4x36 intercooler
Flow master 40’s
Motor stock
