Well my idle surges between 500rpms and 900 rpms, then works its way to 200rpms and 1000 rpms, then dies on occation, it also dies when Im coming to a stop and I push in the clutch every now and again. 40% of the time it idles fine although slightly wavy. I have replaced the AIC and the TPS is new and came with the trottle body, I have tried just about ever idle surging remedy I've read on this site, that includes setting the idle with the AIC unplugged and resetting the TPS voltage. I've heard there is an adjustible bypass valve I could buy that goes inline with the the AIC that could fix my problem. I dont think there are any vacuum leaks either. I have another TPS I could try but Im not sure that would do anything to help. The car ran and idled perfectly before I put the heads/intake/ and rockers on my car. Mods are in the sig. Fuel pressure is at 41psi and is just on the edge of lean, plugs are white with a slightly brown tint to them.
I got some codes from the comp.
KOEO self test
34 - Not sure if this would effect the idle
67 - I never wired the neutral safety switch when I did the swap
81 - deleted emmissions equipment
82 - deleted emmissions
87 - fuel pump is not wired through the comp, it is wired through the ignition switch instead
Continuous memory
14 - I had the TFI tested and it tested fine, so I replaced the Stator, it seems to help alittle but not much.
I bought a code reader and I plan on clearing the codes in the morning then doing a KOEO and KOER test tomorrow night.
Any help is greatly appriciated. I cant have this thing dieing on me in traffic all the time.
KOEO self test
Continuous memory
