If you could buy one mod and had about 300 to 400 dollars to do so with what would it be. that is the question i am asking my self so if you guys could help me out and let me know what worked best for you and gave you the most gains thanks. ![Spot :spot: :spot:](/smilies/spot.gif)
Saleen Mike said:Subframe connectors with cross brace & Alum. driveshaft should both be possible for $400 including install.
If you include labor and reflashing your computer for the new gears, I would think you would be over $500 out the door.
Saleen Mike said:OK, because you did not like my driveshaft idea, combined with me forgetting how poorly the Hurst/Saleen shifter is (I assume you have a 5 speed), I would like to change my suggestion to:
Subframes with cross brace and a Pro5.0 shifter.
Again, both should be able to be had with install for about $400.
You will be able to drive your car much better and use the potential that you have.
(Then when you get another $200 I would get the driveshaft)
