If you had it to do over again
Im a little frustrated with my first mustang today. Cracked intake manifold.....A plastic intake manifold? I am going to ask whoever thought of that to add some coolant for me right after a good hour drive......
Sucks, but it happens. I still have the original on mine with 72,000 miles.
Nice 35th L.E.!
Don't jinx yourself man! The same thing happened when I got mine, and read about the cracking manifolds, saying I still have the stock one and less than a week later it went caput.
I was happy with my car modding it in this order:
1. Exhaust
2. Shifter
3. Suspension
4. Brakes/Show (Grille Delete, Antennae)
5. Gears/Clutch
6. Blower
All this was after routine maintenance. And I love where my car is at now!
Thanks for all the input everyone. I certainly have a lot to think about. Looks like I am going to be driveing her around stock for a while as my rear diff is tore to pieces, but I am still ready to start saveing to mod this thing. I have allways wanted a mustang and I have gone through this with vehicles before with 40k+ trouble free miles after everything was right.
+1. I'm mad at myself for not doing it a year or so ago when I bought new pads and rotors. It wouldn't have been much more, and there's a 'cheap' way to do it:
Get remanufactured 03/04 Cobra calipers from O'Reilly's (because they are the only ones that come with the needed mounting brackets) for about $80 each. Then get some stainless steel brake lines for about $60. And finally, pick a set of rotors/pads. You can get 'decent' quality rotors/pads from the seller "Brakemotive" on Ebay for about $100, but the zinc coating will wear off after a year or so. I'd have to look around, but there's also another seller that sells VERY good quality rotors that come powder coated and supposedly won't rust for around $160. Then add a set of Hawk pads for $60 and you're done.
Voila. Front Cobra brake upgrade for $300-$400.
Also ditto on doing all the maintenance stuff.
Will cobra brakes fit under the stock gt 17's? Wouldn't you have to have some sort of adapter bracket for the caliper since the rotors are bigger?
edit: after some research, the GTs and Cobras used the same steering knuckle, I'm quite surprised. On O'Reilley's website it says they don't carry the calipers in store or online though.Plus it was another $65 per core if they did have them in stock. So make that more like $290.
I did find this loaded pair for $280 though.
They also sell rotors and brake lines, but I'm thinking you could probably source them yourself for cheaper.
