Ignition issues - worth upgrading to MSD?
  • Thread starter Thread starter jb89coupe
  • Start date Start date Apr 20, 2005
jb89coupe
416
CT
Apr 20, 2005
  • Apr 20, 2005
See my sig or garage for my info on my setup..
The car has a miss around 1900rpm, and feels hesitant/unresponsive until about 2500rpm. Once it hits 2500 or so it wakes up suddenly and pulls like crazy up to 6k or so. I've tried a different MAS, TPS is fine, EGR/IAB work, wires are good, no codes, etc.. The only thing I can think of is the TFI module or PIP. When we were tearing my motor down a bunch of the water pump bolts broke off in the block and we had to heat them out (the dizzy was still in at this point). I think we may have cooked the module in the process.
So my question is, would I benefit from upgrading to the whole MSD igntion system, rather than just replacing the TFI/PIP units? Thinking of the 6AL and billet dist. Also, with the 6AL do I use my existing Blaster coil (the direct replacement model) or do I need another one?
notchback
1,950
St Clair Shores MI
Apr 20, 2005
  • Apr 20, 2005
your coil is fine, try to regap the plugs to about .045 b4 you do anything.....
they aren't platinum are they?
if the regap doesnt help do the msd
but it's prob the the module
jb89coupe
416
CT
Apr 20, 2005
  • Apr 20, 2005
The plugs are autolite 24's (not platinum), I have them sidegapped to .055" still from the stock heads. I know the powerheads are milled .040", so I'm not sure what my compression is now. I'll throw some new ones in and gap them a little smaller and see what happens. Just wondering if a capacitive discharge ignition system like the MSD would offer any type of noticable performance improvement with my mods.
H
HappyG
260
  • Apr 20, 2005
yes
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 21, 2005
  • Apr 21, 2005
The stock ignition is good past 350 flywheel HP. Unless NO2 or forced induction is in your immediate future, I would say the stock ignition is fine if all the parts are working like they should be.
87'GTstang
1,025
  • Apr 21, 2005
Yes, the stock ignition is a stout performer, like said, regap the plugs first.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Electrical Multiple spark with spout in, normal when out
  • Cumstang59
  • Dec 28, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Feb 5, 2025
Cumstang59
C
Resolved 1989 Mustang GT no spark, no trigger pump relay
  • Nine Finger Wrenching
  • Nov 26, 2023
4K
Fox 5.0 Mustang Tech Nov 30, 2023
J
The Money Pit
  • jessie Clark
  • Sep 14, 2024
  • The Welcome Wagon
The Welcome Wagon Sep 14, 2024
89ripper
Car idles good, then VERY SUDDENLY dies
  • Vulpes5.0
  • Jan 17, 2024
5K
Fox 5.0 Mustang Tech Feb 4, 2024
Vulpes5.0
