  • 2.3L (N/A & Turbo) Tech
Ignition module or coil pack problem?
  • Thread starter Thread starter Jason Green
  • Start date Start date Aug 10, 2005
Jason Green
1,438
Winnipeg, MB
Aug 10, 2005
  • Aug 10, 2005
1993 Mustang 2.3L ran for 10 mins then died. Tried to restart and it wouldn't fire. Turns over excellent just won't fire. Fuel pump is fine. I changed both the DIS ignition module and the front coil (got them at a wrecker used). Car still won't run. I am assuming the used parts I got were no good.
How can I tell if it's either the DIS or the coil pack?
T
Touring23
294
Washington
Aug 10, 2005
  • Aug 10, 2005
Check for diagnostic codes first; every DIS fault I can think of will set a code.
Confirm fuel pressure at the fuel rail.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Aug 10, 2005
  • Aug 10, 2005
See if the tach is showing an rpm while cranking...the ignition module controls the tach.
Jason Green
1,438
Winnipeg, MB
Aug 11, 2005
  • Aug 11, 2005
The tach stays on 0 rpm while I crank the car over and over.
Dan P.
483
N.C.
Aug 12, 2005
  • Aug 12, 2005
Sounds like the ignition control module on the lower intake manifold.
Jason Green
1,438
Winnipeg, MB
Aug 12, 2005
  • Aug 12, 2005
Damn, I just replaced it from one from the wrecker. Is it possible the one I got was bad or I somehow fried it after I installed it?
16vstang
100
Way up in Maine
Aug 13, 2005
  • Aug 13, 2005
With thouse it ALWAYS better to go new, mabe a bit more but will save you in the long run. I went through that a bit ago started with the primary coil misfiring into the block. So I replaced the coil with a NEW one and all was well for a bit till the dis went tach went crazy, no fire to one coil pack, no fire to certian cylenders on both sides then fianly dead. No fire what soever. So 120 bux latter it ran better than it ever had. Probaly not what you wonted to hear, but hope it helps ya
Jason Green
1,438
Winnipeg, MB
Aug 14, 2005
  • Aug 14, 2005
$120, I wish. A new DIS here is $299 (CAD) + tax.
So even if my tach isn't acting up you still think its the DIS?
stangs4evr-roy
57
  • Aug 14, 2005
$176+ tax at crappy tire and make sure you use some dielectric grease on the back of the module when you put it on or you will blow it too. the classic symtoms are tach only shows half the rpm's and it should throw codes 223-224 if it is the module.
barnfindstang92
VA
Nov 9, 2008
#10
  • Nov 9, 2008
  • #10
codes 223-224 ignition module wows FC 126
My car also has FC 223 224. The tech is also at half.
What is causing these ignition modules to fail?
Reason why I ask, I used to have a 86 SVO that went through 3 TFI ignition modules. Yes, I used dialetric grease every time I replaced it. After I sold the vehicle, I was told that a faulty coil may have been the cause of the 1.5 year life span of the ignition module. Can these DIS coils cause the ignition module to go bad? Is there a resistance that can be checked with this type of coil?
Car also has FC 126 MAP or Barametric sensor out of range.
Any special check for MAP or Baro sensor?
Stinger
7,754
24
118
Nov 9, 2008
#11
  • Nov 9, 2008
  • #11
The TFI's are just failure prone, the coil has nothing to do with it.
Even though this thread is old, sounds like the original poster had crank sensor issues.
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
2.3l mustang hard starts and bogs and stalls when you floor it from idle
  • declan
  • Feb 19, 2025
2K
2.3L (N/A & Turbo) Tech Feb 28, 2025
declan
D
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
