  • SN95 4.6L Mustang Tech
IGNITION PROBLEMS PLEASE HELP!!!
  • Thread starter Thread starter david211duff
  • Start date Start date Dec 14, 2012
david211duff
Tucson, Az
Dec 14, 2012
  • Dec 14, 2012
I'd like to begin with apologizing, I'm new to this site and its urgent so I post where I thought I was supposed too.
I have a 1998 mustang gt. I recently went to shut my car off and pulled the key out of the ignition but the car continued to stay running. It is now stuck in the on position. I had to unplug the battery to shut the car off. The car is equipped with transponder keys. I bought a new ignition cylinder without the transponder keys, came with a new set without the chip, put it in and the car cranked but would not start. The theft light blinked the entire time. The entire time the new tumbler was in, I would turn it off but the car stayed in the on position (check engine light dash lights on including radio, as if the key was still in). Basically I'm wondering what I should do, buy another new ignition that comes with new transponder keys and or I'm thinking about hot wiring it somehow as a temporary fix but I'm not sure how to bipass the actual transponder "theft" portion.
N
n0v8or
604
Rhode Island
Dec 15, 2012
  • Dec 15, 2012
The key cylinder and ignition switch are two separate parts, with a mechanical linkage between them. Since you can operate the starter with the key, I think your mechanical linkage is OK. I would go back to the original key cylinder and instead replace the ignition switch. The switch connector is retained by a bolt, and the switch assembly with 2 screws.
Reactions: kramer
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 15, 2012
  • Dec 15, 2012
+1 on above. Your problem is in the ignition switch. Replacing the ignition switch does not require re-programming of PATS.
Reactions: kramer
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Resolved 1996 PATS help needed
  • Bajaboy
  • May 21, 2025
SN95 4.6L Mustang Tech May 23, 2025
Bajaboy
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
