stock 351 block punched 30 over, stock crank, stock 69 351 rods polished, shotpnd,ported trick flow heads 202/160's, comp cams 575 lift, 260 duration 112 CL *nitrous cam*
Pistons,TRW forged L2456F .030 356CI, 60.4cc 11.37CR, 63cc 11.00CR, 69cc 10.24CR comp dist 1.769 .210 dome, really scared to clay the motor with this piston, should I have the dome cut flat ? will I have to have trick flow valve rel's cut if my block has not been cut?
Also, the heads have not been cut either.
All stuff after .50
Victor Jr ported to match heads BTW.
Thank you fellas.
All stuff after .50
Thank you fellas.
