IMRC cleaned now car won't start.
big nasty
65
Montezuma, GA.
well i finally got around to clean the IMRC butterflys, secondaries and replace the controller.
today i put everything back together along with new air filter, spark plugs, oil, and coolant.
bottom line is the car will not start. I put everything back together the way it came off. it sounds like it may not be getting fuel. when i turn the key everything on the cluster moves except for the oil guage
How should the fuel injectors look when seated. i can still see a little bit of orange which is right above trhe o-ring, but it will not go down further.
BTW tha car has been sitting for about 3 weeks, but was runing ok before
I NEED HELP ASAP
Thanks
stephen
If it sat for anylength of time the fuel may have drained from the fuel lines. Turn the key on and off about 15 times to "prime" the fuel system. You should hear the fuel pump rumming for about 3 seconds when you do this. Its quick and easy and has helped me a couple of times. Of course it could be something else. :flag:
