Fox In search of a Spec clutch dimension.
PonyGTrider
5 Year Member
Feb 27, 2019
644
113
63
Mexico
Hi all,
Just a question to all of you owning a Spec stage 2 or 2 plus.
If you have a non installed brand new Spec stage 2 or 2 Plus.and if you can share this imformation…
Need the height or air gap in between the mounting surface to the pressure plate. Without the friction disc installed. I need to verify that dimension against my clutch highlighted on the pic.
I called Spec customer service but they couldn’t give mi that dimensions.
The only dimension they gave me was the clutch release travel dimension which is 0.375” and the pressure plate retrieving measurement, that being 0.060”
So if anyone has that dimensions on a brand new clutch and you can share it, I will greatly appreciate it.
Thank you
