Indexing Bellhousings
Glen's 1965 5.0
477
Tomball,Texas
When indexing a bellhousing for alignment, does anyone know what the out of center tolerances are for a Top loader for a big block??? I have a top loader that is popping out of second gear on the downshift and with a full rebuild and a good second gear and slider that was in excellent shape, I suspect a tranny / bellhousing problem.
Thanks
Thanks..
A new shifter was installed and adjusted every which way but loose. All syncros are new. Pulled the tranny and it appears that the top spring over the 1-2 shift rail had broke and would not apply enough pressure to keep the rail in place. Will replace that and then see what happens.
