Information about 2011 5.0
randeez11
Hi guys. I have had my Mustang GT on order for 8 weeks. I spoke to my salesperson last week and he said there were a few problems occuring. He said something about a " spring" that needed to be looked at. Also, he spoke to someone he knows from the plant. I live in Windsor, Canada, the plant where the 5.0 engines are being built is about a mile from my house. Someone there told him that they have been having recalls on the engines. They told him that the tolerances in the engine were really tight and require proper break in. People have been getting their cars and beating on them right away, engine damage has been occuring.The factory is going to add a break in additive to the oil. As a matter of fact, they are using "GM" break in additive believe it or not.
All I know is , before I get my car, I do not want anyone else beating on it once it arrives at the dealer. I had fully intended to brealk it in easy myself. I have built several engines and have always broken them in before flogging on them.
Anyways, my car has not even been built yet ! But maybe that is a good thing. All the bugs should be out by the time they get around to mine, I hope.
Just thought ou guys might want to hear this, Randy
No, I really didn't want to hear that! My car was ordered 8 weeks ago, and is in a warehouse in NJ waiting for a change in trucking companies to happen. I told my dealer that I want to make sure there are only like 3 miles on the odometer when I get it since I've seen the joyriding videos on YouTube! I want to break the car in correctly.
Honestly, I don't believe much of what your salesman says, most dealerships are actually clueless when it comes to the production of these cars. Did he even mention that the plant is shut down now for 2 weeks for maintenance?
There are TONS of people who have already got their 5.0's and haven't had ANY problems. I haven't heard of any engine failure.
Also, as far as having 3 miles on the odometer when you get it.. the dealership can't control that, some cars are randomly selected for extended testing and can come with 60-70 miles on them already. Most come with 13ish.
Yup, the salesmen usually are clueless. Also, I won't mind if the mileage is from Ford. I have read they leave a note in the car if there was extended testing being done on it. I just asked my salesman to make sure no one at his dealership takes it out.
From the manual:
BREAKING-IN YOUR VEHICLE
Your vehicle does not need an extensive break-in. Try not to drive
continuously at the same speed for the first 1,000 miles (1,600 km) of
new vehicle operation. Vary your speed frequently in order to give the
moving parts a chance to break in.
Drive your new vehicle at least 100 miles (160 km) before performing
extended wide open throttle maneuvers and at least 1,000 miles
(1,600 km) before towing a trailer or before performance/competition
conditions. For more detailed information about towing a trailer, refer to
Trailer towing in the Tires, Wheels and Loading chapter.
They also state that your engine should not run anything but Ford motorcraft plugs, oil and filters too because it could shorten engine life, but we all know that's not so. ;)
From Woody at Ford Strokers
Congratulations on your recent Fordstrokers engine purchase. The topic of breaking in a new engine is very subjective and ask 10 people and you will get 8 answers. I will outline the VERY simple steps I have used for the last 15 years. It's not rocket science, it's very simple and effective.
If you are a short block purchaser WITHOUT an oil pump, oil pan, pickup installed. I can NOT stress enough how important oil pump pickup to oil pan clearance is. This clearance is the difference between life and death in a very short time. I recommend .375 to .500 clearance between the pickup and the bottom of the pan. This has worked for me for the last 15 years, but you would be surprised how many people don't even think to measure this clearance. IF the pickup is laying on the bottom of the pan, expect oil starvation very quickly.
If you purchased a short block or long block with oil pump, oil pump pickup and oil pan installed, you need not worry as we have set the pickup clearance already.
Each engine is hand assembled and we use a special teflon additive assembly lube, yes it is very sticky, very messy BUT you MUST ALWAYS prime the oil pump mechanically before starting your new engine for the first time. If you do not own an oil pump shaft priming tool, you can easily use a 1/4 inch extension with a 1/4 inch socket taped to the extension and chucked in your drill. Proceed to spin the drill counterclockwise for 15-20 seconds, rotate the engine 1/4 turn, continue to run the drill again for another 15-20 seconds and turn the engine over by hand another 1/4 turn. Do this until you have turned the engine over a full revolution AND you have oil at all pushrods.
As for the actual break in, unless you have had specific instructions from me in regards to your engine, keep it simple. Run a good oil filter. I have used an FL1A for 15 years with much success, I ALWAYS run a large magnet on the outside of the oil filter, (it obviously won't fall off ) this will keep any small particles in the filter that may have otherwise gotten by.
Again unless I have given you specific instructions, run any name brand conventional 10w30 motor oil. I always do two quick oil changes, about 75-100 miles apart, then cut the filters open to make sure there is nothing in there. After 1000-1500 miles, feel free to run any oil you are comfortable with, whether it be conventional or synthetic.
Now onto the piston rings, the way we hone nowadays and the rings we use, rings are typically seated within minutes, after a few full heat cycles, the rings are surely seated. Take precaution to minimize washing the cylinders with gas on initial startup, if all goes well on the first start, run the engine for a few heat cycles. Feel free to do a leakdown and you will see the rings have seated almost immediately. Once you are comfortable, by all means go ahead and start banging gears. If there is a problem with the engine it will rear it's ugly head quickly. I don't follow or buy into the 1000-2000 mile break in theory, I run my engines hard right from the get-go, and my engines are no different than the one I built for you.
The above guide is strictly a guide, your engine we built may not adhere to the above steps, BUT you will know this because we will talk about your specific engine and I will tell you what steps to follow, but the above guide is a good method to use and has treated me and 100's of my engine customers well.
As usual, any questions please use the contact us page on my store here and we can discuss, again I appreciate your business and friendship more than you know. Take Care
