Injector and maf help please
Im looking for a set of 30lb injecotrs but found stock LS1's have 28's, i can buy them dirt cheap but didnt know what i would do about a maf. Would i just get a maf for 30's and be ok what would have to be done or would it just not work? Do you have to have 19,24,30 etc. sized injectors on mustangs?
Im putting a big dry kit to my car and want to make sure i dont lean out.
um, I've seen "adjustable" maf meters before, wth a knob on them that you can turn to change the tune of them. That mght work. And it's close to 30 so you might be able to get by with higher fuel pressure. The safest way would be to do a wet system but you probably already know this and have your reasons for a big dry shot. So. Good luck. :flag:
If i get a new maf ill only get pro-m. I saw they have a small box that piggybacks the maf and lets you adjust but its pretty vague as to what sizes or if you have to be on a dyno and play with a/f ratio to set it right. If it works with the stock maf then i could get it but buying a new maf and the adjuster is too much money.
