Injector/Computer Remapping Question
craZy400
I just bought a complete "take off" fuel injection system from an '86 5.0 H.O. that I want to put on my '92 5.0 H.O. It has only seen the factory firing and no miles. Super clean and would be nice to start with a fresh set up.
Here is the catch. The fuel injectors are grey tops which means they are 14lbers. They only produce 140cc @ 3bars. Part number: E67E-B4B I found that these were only supposed to be on 4 and 6 cylinders so I am not sure how the heck they came on this set up. There are 8 of them and the rest of the fuel injection parts are 5.0 H.O. stuff.
My '92 injectors produce 194cc @ 3bars. Part number:E6TE-A2B
I assume this will cause a lean condition? Is there a way to remap the computer to compensate for the difference in cc's?
There are a few differences in the upper intake and the throttle body but I assume that is to reduce air flow or accomodate for the speed density system some how?
I know I could just go buy 19lbers and be done but I was hoping to use this set up since it practically brand new and I already spent the money. Plus I hope that this would give me an extra 1/2mpg :-)
Thanks for any insight.
Ty Rogers
765.461.5048
If you have an adjustable fuel pressure regulator, you can turn up the fuel pressure to achieve a 19 lb flow.
According to the calculator I have, you need 70 PSI if the 14 lb rating was at 38 PSI. If the injectors were rated at 3 bar (44.1 PSI), you will need 83 PSI.
I might have an opprotunity to buy 19lbers but they are flow rated at 210cc @ 3bar which is over my stock 19lbers which are 194cc.
Wouldn't this cause a rich condition?
Or would the computer be able to compensate for it?
thanks again
Ty
craZy400 said:
Wouldn't I need a larger fuel pump to be able supply that regulator then? Sounds like a good way to increase leaking in the engine compartment :-(
In theory, it is still only 19 lbs per injector, so the pump size would remain the same. In practice, I problably would increase the pump size from 88 LPH (stock) to 112 LPH.
thanks again
Ty
Stick with the Ford orange (old dirty ones look tan) injectors and you will have much less problems. The computer will trim the fuel flow at cruse by using the O2 sensors.
