Injector HP Ratings?
  • Thread starter Thread starter snoboardcore
  • Start date Start date Oct 3, 2005
snoboardcore
276
New Hampshire
Oct 3, 2005
  • Oct 3, 2005
Hey guys i am currently running 24 lb injectors any idea how much hp they can support? I am going to throwing a different pulley on the s/c and be running around 7-9lbs so im thinking im going to need to be putting the fmu back on for the amount of power i am going to be putting out. I have 42lbs coming but i need the maf for them and i wont be getting that until mid winter early spring.
L
luckythirteen13
648
Anaheim, CA
Oct 3, 2005
  • Oct 3, 2005
id wait to put the sc pulley on untill you get the 42's in
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 3, 2005
  • Oct 3, 2005
i was told not sure if its true they support from 260-320 hp again not sure if this is true but is what i was told.
L
luckythirteen13
648
Anaheim, CA
Oct 3, 2005
  • Oct 3, 2005
the hp rating is lower when the car is sc'd
C
criticman
723
Rome, GA
Oct 3, 2005
  • Oct 3, 2005
Plus, you need to consider what fuel pump you have when taking into consideration what injectors you need for your setup.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 4, 2005
  • Oct 4, 2005
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle.
Example:
19/.5 = 38, 38 x 8 = 304
24/.5 = 48, 48 x 8 = 384
30/.5 = 60, 60 x 8 = 480
The preferred duty cycle is about 85% maximum, so for a safety factor mulitply the final figure times .85.
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
Here's where I will lose some of you for lack of understanding:
Increasing the intake manifold pressure above atmosphereic decreases the flow rating by the amount of pressure increase.
Example: injector flows 30 lbs at 39 PSI. You have 10 PSI boost, subtract the 10 PSI boost from the 39 PSI fuel pressure. That means you have 29 PSI pressure at the injector tip. Therefore, a 30 lb injector flows 25 lbs with 39 PSI base fuel pressure and 10 PSI of boost.
Fortunately, the design of the fuel pressure regulator causes pressure to increase as manifold pressure increases. The increase may not be linear though.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
