Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle.
Example:
19/.5 = 38, 38 x 8 = 304
24/.5 = 48, 48 x 8 = 384
30/.5 = 60, 60 x 8 = 480
The preferred duty cycle is about 85% maximum, so for a safety factor mulitply the final figure times .85.
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
Here's where I will lose some of you for lack of understanding:
Increasing the intake manifold pressure above atmosphereic decreases the flow rating by the amount of pressure increase.
Example: injector flows 30 lbs at 39 PSI. You have 10 PSI boost, subtract the 10 PSI boost from the 39 PSI fuel pressure. That means you have 29 PSI pressure
at the injector tip. Therefore, a 30 lb injector flows 25 lbs with 39 PSI base fuel pressure and 10 PSI of boost.
Fortunately, the design of the fuel pressure regulator causes pressure to increase as manifold pressure increases. The increase may not be linear though.
See
http://users.erols.com/srweiss/ to get the calculators used in these examples.
