injector install
Ok i got a set of new Ford Racing 19 pounders for christmas since mine are ****tin out (well acculy more like one but it has already been replaced and so i decided to just do em all). And anyway i was wanting to see if anybody has any advise, i already picked up a new fuel filter and ran a tank of cleaner thru it to try and break loose some more ****. I need to get to autozone and get one of those fuel line tools but the last time i was there the guy there was a total dumbass and was no help so i just left. Also i was wondering if i would need an uppler to lower intake gasket...now that i think about it i probley will but oh well just any advise or tips would be appreciated.
thanks for your help in advance...
You don't need the fuel line tool, just move the rail out of the way. Yes, a new upper to lower gasket will be needed. You'll also need new o-rings. Make sure none of the old ones are still stuck in the rail. That's pretty much it, but this would be a good time to install an AFPR if you don't have one yet.
If youve never had the top intake off theres a bracket in dirvers side back thats a pain, dont forget to take it off. You should be able to reuse that top gasket. If you didn't get orings with those injectors get some, 2 per injector and it would probly be good idea to replace vacuum hoses while youre there
