Injectors??....will i need bigger ones?
SilverFox90 said:
my mods are listed in my sig and i am planning on a set of thumper e7s this winter plannin on stayin with the stock cam...should i upgrade to 24# injectors or not?...or would adding an AFPR be enough for my mods?
stay with 19s unless you are doing cam to go with those heads , not to mention a MAF ..... stockers should be more than enough AFPR is all you will need ......
I wouldn't say the 19lbs will take it easy in the upper rpms but if you add an AFPR and bump it up a bit you will be fine...even in the "outrunning the injector" high-rpm phase...
Just to let you know the 93 Cobra has similar modifications done to it as your car has and it comes from the factory with 24lb injectors/matching bigger MAF...
You dont need them but when you decide you need replacements you could go one size bigger! If you have the stock cam I would sure like to see some 1.7 Cobra Rolling Rockers. Of course I am sure you know that new heads would make those bigger injectors really purr.
so will would a set of 1.6 or 1.7 rockers be better with stock cam and thumper ported heads?...thanks for the help ill prolly just get the AFPR for now and add the 24# injectors later on down the road when i have money and if i add a 75hp nitrous system
Well if you get the thumpers with the gt40 spring upgrade the 1.7's would be fine...that is what I had on my stock headed/springed heads so they would be fine with your stock cam with thumper heads/upgraded springs...
i would get the 24s and upgrade your MAF while your at it if you got the cash.
i would go with 1.7 rockers too with the stock cam and those heads. you will see more performance out of the cam and see what you want with those heads.
