Finally got the car back to 100%! The P1506 error code was none of the above as far as solutions. I replaced the PCV valve(didn't help) and was going to replace the IAC when my buddy came up with the genious idea of switching his IAC from his 96 Cobra(which has no problems) to my car and both cars ran the same - we even installed my IAC on his car and it ran fine - we decided not to switch them back b/c it wasn't a problem! I still had the check engine code and the car still had a rough idle when put into neutral. So we lowered the idle about 150 rpm's to 900 rpms exactly and the problem went away! Now instead of it jumping from 1,000 to 2,000 when put in neutral it jumps from 900 to 1050 on occasion. More importantly it does not throw any more codes. Just wanted to share that progress for those who had helped. Thanks again.
Now I need to adjust my speedo because it is clearly off with my new setup.
Things I am concerned about are the new 4:30 gears and my 18 inch Saleen rims. How will I adjust the speedo to compensate for these two factors? Also, my compression is lower than stock(ready for a supercharger), so will this affect calibrating my speedometer? I add this point about compression because it makes my 4:30 gear behave more like a 4:10 would as far as rpm/mph ratio.
Any thoughts on calibrating this setup....Thanks in advance!
