Installing a new wiring harness
I have a 87 mustang hatch back. It has been switched over to a carb setup with MSD ignition and MSD distributor. The wiring harness in this car was a nightmare, corroded wires, open wires I had always wanted to swap in a wiring harness to ensure safety and reliability for the year I’ve had it. Well I started about a couple weeks ago and it’s been more difficult than I originally thought. I bought a universal 21 circuit wiring harness stripped out my old harness and started laying out themes wires in the car I’ve got them ran to where they need to go in the engine and the back half of the car. I’m just running into issues while hooking up my original accessories such as alternator. The alternator worked before. In my universal harness I have an alternator power wire and also an alternator executor wire. I have some wiring diagrams printed off for the stock alternator and I thought I had them hooked up right but I’m still not charging if someone could help me out that would be amazing
EFI to carb conversions are always nightmares and cause more wiring and electrical problems than even the worst EFI system. There aren't words in my vocabulary to describe what I have seen here on Stangnet when it comes to EFI to carb conversions.
I take that last sentence back, there are words to describe it...
It's like doing a heart transplant on a beautiful woman, but using a PIG's heart as the donor heart...
Alternator troubleshooting for 86-93 5.0 Mustangs:
Never, never disconnect an alternator from the battery with the engine running. The resulting voltage spike can damage the car's electronics including the alternator.
Revised 28-Nov-2018 to add warning that the instrument cluster must be in place and working for the alternator to charge
Red color text applies to cars with a 3G alternator.
Do all of these tests in sequence. Do not skip around. The results of each test depend on the results of the previous tests for correct interpretation.
Simple first step: Remove the alternator and take it to your local auto parts store. They can bench test it for free.
Use a safety pin to pierce and probe the insulated connectors from the rear when doing tests with the connector plugged into its' mating connector.
Engine off, ignition off, battery fully charged.
1.) Look for 12 volts at the alternator output. No 12 volts and the dark green fuse link between the orange/black wires and the battery side of the starter solenoid has open circuited.
3G alternator: Look for 12 volts at the stud on the back of the alternator where the 4 gauge power feed wire is bolted.
No voltage and the fuse for the 4 gauge power feed wire is open or there are some loose connections.
2.) Look for 12 volts on the yellow/white wire that is the power feed to the regulator. No 12 volts, and the fuse link for the yellow/white wire has open circuited.
The alternator MUST have the instrument cluster in place and working properly. The alternator warning light is a part of the charging circuit. No cluster, then no working alternator.
Engine off, ignition on, battery fully charged
1.) The alternator warning light should glow. No glow, bulb has burned out or there is a break or bad connection in the wiring between the regulator plug and the instrument cluster. The warning light supplies an exciter voltage that tells the regulator to turn on. There is a 500 Ω resistor in parallel with the warning light so that if the bulb burns out, the regulator still gets the exciter voltage.
Disconnect the D connector with the 3 wires (yellow/white, white/black and green/red) from the voltage regulator.
Measure the voltage on the Lt green/red wire. It should be 12 volts. No 12 volts and the wire is broken, or the 500 ohm resistor and dash indicator lamp are bad. If the 12 volts is missing, replace the warning lamp. If after replacing the warning lamp, the test fails again, the wiring between the warning lamp and the alternator is faulty. The warning lamp circuit is part of the instrument panel and contains some connectors that may cause problems.
2.) Reconnect the D plug to the alternator
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed voltage regulator. This is an actual measurement taken from a car with a working electrical system. If you see full or almost full12 volts, the regulator has failed.
Engine on, Ignition on, battery fully charged:
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see battery voltage minus .25 to 1.0 volt. If the battery measured across the battery is 15.25 volts, you should see 14.50 volts
Familiarize yourself with the following application note from Fluke: See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachments\568093
You will need to do some voltage drop testing of several of the wires.
Start looking for these things:
1.) Bad diode(s) in the alternator - one or more diodes have open circuited and are causing the voltage to drop off as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Do the voltage drop test as shown in the Fluke tech note link. Measure the voltage drop between the alternator frame and the battery negative post. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
3.) Bad regulator that does not increase field current as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
4.) Bad sense wire - open circuit in sense wiring or high resistance. The yellow/white wire is the voltage sense and power for the field. There is a fuse link embedded in the wiring where it connects to the black/orange wiring that can open up and cause problems. Disconnect the battery negative cable from the battery: this will keep you from making sparks when you do the next step. Then disconnect the yellow/white wire at the alternator and the green fuse link at the starter solenoid/starter relay. Measure the resistance between the alternator end of the yellow/white wire and the green fuse link: you should see less than 1 ohm. Reconnect all the wires when you have completed this step.
5.) Bad power feed wiring from the alternator. Use caution in the next step, since you will need to do it with everything powered up and the engine running. You are going to do the Fluke voltage drop tests on the power feed wiring, fuse links and associated parts. Connect one DMM lead to the battery side of the starter solenoid/starter relay. Carefully probe the backside of the black/orange wire connector where it plugs into the alternator. With the engine off, you should see very little voltage. Start the engine and increase the load on the electrical system. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
Alternator wiring diagram for 87-93 Mustangs.
attachments\568094
The following are diagrams courtesy of Tmoss & Stang&2birds
Alternator wiring diagram for 94-95 Mustangs.
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch
100 mV Ground
0 mV to <50 mV Sensor Connections
0.0V bolt together connections
Alternator wiring circuit
Notice the green wire connects to a switched power source. The circuit contains a 500 ohm resistor in series between the switched power and the alternator. Connecting it to switched power keeps the regulator from drawing current when the engine is not running. The resistor limits the current flowing through the wire so that a fuse isn't needed if the wire shorts to ground.
Also notice the sense wire connects to the starter solenoid and it is fused. It connects to the starter solenoid so that it can "sense" the voltage drop across the output wiring from the alternator.
Fuse link for 86-93 Mustangs
Replacement parts:
14 gauge fuse link for stock alternator.
Bussman BP/FL14 Fusible link
AutoZone
Dorman - Conduct-Tite 14 Gauge Fusible Link Wire Part No. 85620
Advance auto parts #85620
Pep Boys - SKU #8637594
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
https://www.stangnet.com/mustang-forums/attachments\21328
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
attachments\568093
attachments\568094
300 mV Switch
100 mV Ground
Replacement parts:
AutoZone
HVAC vacuum diagram
Fuse box layout
Starter circuit
I have seen this post before. I do not have a stock instrument cluster I have all autometer short sweep electrical gauges. I thought I could just wire up the alternator with the 12 volt input to signal the alt to start charging with the output voltage going to the battery to charge it.
Also in my new harness I have a problem getting my power windows to work. In every wiring diagram I can find it’s showing that there is a pink and black wire to power both switches and make the windows work so I tied into those wires with twelve volts and I have power at the switches but no movement on the windows both motors are good I verified this by tying straight into the motors to roll the windows up and down. Any help?
No matter who makes the cluster, the exciter circuit needs to be present and functioning. A 500 Ω resistor in series with the switched 12 volts is the best method to power the regulator green/red wire for aftermarket or custom installations..
So I stripped out my car of the original wiring harness. In my new harness I have a hot wire with the key on for the power windows. I left the old wiring in the doors and the chunk of the harness that ties the two power window motors together from side to side. There is a plug in that chunk of wires that supplies power to the power window circuit so I put twelve volts and ground to it expecting my windows to work on the switches but they don’t. Obviously or I wouldn’t be asking for help. I have power on the switches but when I use my test light to see if the power jumps to another wire, all of the wires including the grounds become hot. THIS might drive me insane I have been trying to figure this out for two
So I stripped out my car of the original wiring harness. I bought a universal harness with plans to just cut my plugs for all my accessories off of my old harness then wire them on to the new one. In my new harness I have a hot wire with the key on for the power windows. I left the old wiring in the doors and the chunk of the harness that ties the two power window motors together from side to side. There is a plug in that chunk of wires that supplies power to the power window circuit witch is a pink and black. so I put twelve volts and ground to it expecting my windows to work on the switches but they don’t. Obviously or I wouldn’t be asking for help. I have power on the switches but when I use my test light to see if the power jumps to another wire, all of the wires including the grounds on the back of the window switch become hot. THIS might drive me insane I have been trying to figure this out for two weeks.
The way the wiring for the windows and power locks in these cars is confusing. It took me forever to figure out how to install a new alarm in my car. My best advice for you is to go to a website called The 12volt. Those guys over there helped me out a ton fixing my power locks.
Got the power windows working just had to build my own harness using the factory switches no biggie lol but I’m a till having problem fooling the alternator into charging. I wired in a 500 ohm resistor into the exciter wire but still just reading the 12.1 volts that is coming from the battery. Does anyone know what the exact voltage needs to be to activate the alternator to charge maybe I need more resistance or less?
The other way would be to use a gm single wire alternator. The wire that has the resistor is the green one. The white and black stripe should run from the main connector to the small connector ( little blade ) in the casing. If you have 12v at the battery main wire...at the green wire and coming out to the connector should be switch power 12v...the yellow should be 12v constant. If you have these things with the key on and vehicle running then there is a wiring issue on whichever one doesn't have 12v.
A factory alternators wiring is similar but has a connector with two black/orange stripe wires.
Reactions: kiddiccarus
