Installing a Tremec TKO 600. A question about the tranny mount.
Hey guys. I tried the search but couldn't find what I was looking for.
I have the stock tranny out of my 04 Mach 1.
Now I'm about to install the Fidanza flywheel and clutch stuff and Lakewood bellhousing.
Now when I bolt the tranny up. Will the stock tranny mount/ crossmember work? Or do I need to do some modifications? And if I do what are they?
Thanks alot for your time,
Mike
It really depends how the tranny sits.. When I replaced mine, neutral center is high and to the right. So, the driveshaft rubbed the body... I had to cut out some space for the driveshaft to clear, but could have altered the trans. cross member as well. If I was to do it again, I'd alter the cross member..
some people say you need to flip the crossmember around and redrill the holes for the mount. I have been trying to figure this out too since I will be installing that same setup in my car hopefully next spring. Modular Depot has some good info on it about the swap as does Modular Powerhouse.
