Installing GT40P heads on 109k block
hbk_136
194
Southeastern GA
I have a stock engine block currently with 109k miles on it. I want to put a set of GT40P heads on there. Is this a good idea, i have heard negatives from this, and others say it will be fine. Has anyone else here slapped on some performance heads on a rather higher mileaged engine? Help me out with some opinions please. :hail2:
I have a 142k on my 93 shortblock...and in 2 weeks I'm installing AFR heads, FTI cam...and all that and I'm not worried about it...
Your car ain't even broke in yet...what are you talking about :D ...
Seriously...you will be fine :nice:
Mileage alone is no indication of the engine's condition. I've seen relatively low mileage motors that are shot; and high mileage motors that are in fine condition. The wise thing to do would be to run cranking compression and/or leak down cylinder pressure tests on it before you mod it. That way you'll know that you're gonna get the most out of your new heads (and other mods) before you bolt them on. Nothing worse than spending all that money only to find that the short block is underperforming, and at some point you're gonna have to pull it all off to refresh the short block. Don't simply guess at the condition of your short block - run the proper tests so you have some certainty.
