installing lowering spirngs - how difficult?
  • Thread starter Thread starter 90lxfoxbody
  • Start date Start date Feb 21, 2006
9
90lxfoxbody
264
  • Feb 21, 2006
title says it all. will i need any special tools or equipment? i am sure i will need to pick up a spring compressor. and while i'm thinking about it - what are the pro's and cons of a 1.5" drop on a fox body?
rd
3,316
63
109
Ocean Springs MS
Feb 21, 2006
  • Feb 21, 2006
The rears are easy, just remove the lower shock bolt and rear swaybar. Then take the rear lower arm bolt out, and let the arm down with a jack. Installation is the opposite.
The fronts are a pita. Same basic deal. I leave the pivots bolts in place and take the lower ball joint and tie rod end loose. Also remove the sway bar. Lower the arm with jack carefully. You can usually remove the stock springs at that point. The stock springs have to be compressed to go back in. Lowering springs can usually be shoved back in. A compressor makes it much easier. I use a homemade inside compressor. Some compressors will not come out the lower hole in the control arm. Go slow and be careful.
C
criticman
723
Rome, GA
Feb 21, 2006
  • Feb 21, 2006
It is fairly easy. Yes, the rear is far easier than the front. A pointer/tip for the front: Use a pipe/bar from up under the A-Arm through the spring to help keep it from popping off track while using a floor jack to push up the a-arm and spring into place up top. It seemed to help.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Feb 21, 2006
  • Feb 21, 2006
did mine and i dont want to half to do it again. The back was real easy but the front is what got me. Good luck!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 21, 2006
  • Feb 21, 2006
The Rear is easy as you do not even need to remove the bolts from the Lower Control Arms. The by far safest way to do the fronts is with a Ford internal spring compressor, its expensive but you cant put a price on safety IMHO.
blackstangt
460
ny
May 3, 2006
  • May 3, 2006
i did the fromt with a friend, we didn't need a spring compressor, just a jack. but we are smart enough to do this safely.
ram360
2,162
Pennsylvania
May 3, 2006
  • May 3, 2006
Just disconnect the rear shocks and lower the axle. No need to do anything with the swaybar or control arms. That's just unnecessary work
DeadLifter
183
Portland, IN
May 3, 2006
  • May 3, 2006
Will be a good idea to get caster/camber plates. I bought mine with springs already installed too tight to buy caster/camber plates. Alignment shop had to drill rivets and stuff out in shock towers to align front tires cost bout $80.
F
FordGuy88
241
Park Ridge, IL
May 3, 2006
  • May 3, 2006
What I did for the front and this was soooo easy was put a jack under the a-arm (touching it). Unbolt it from the k-member and let it down. Before hand un bolt the sway bar. You will be able to pull out the spring and put the new one in. Jack it back up and bolt the a-arm back in.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
