Installing my control arms tonight, any suggestions?
The only suggestion I'd give is to do one at a time. If you disconnect both sides at once (lower or upper), the axle is likely to shift and make realignment a big hairy PITA. Beyond that, no worries. :D
theres a lot of :taco:'s in this thread
LOL JK How the install go i'm waiting on my to come in but i got Granatelli Motorsports ones. I read on MM that you have to torque the bolts after the cars on the ground thats impossible on my car i can't fit under it then
Maybe take it to a shop that has a drive on lift and get under it? I dunno, i cant imagine doing it any other way.
Good luck
All you have to do is put a load on the suspension, so just jack up the car using the pumpkin and you have a load on the suspension. On a side note, how do you initially set the weight jackers, because I just put on a set and the car sits funny.
