installing my MGW..can't get my center console out
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
I thought I'd put the MGW in and I got the armrest off and the screws at the back of the console and the two on each side at the front. But I can't seem to get the console to pop out:bang: . Am I missing something here is there more screws at the fron that I can't see.
why are you taking the console out? i know its been a while, but when i put my hurst in, i just popped the square plastic thing off, and the boot, then unbolted the 4 screws on that heat plate jobbie, then took the 4 bolts loose, pulled the old shifter out, then put new silicone on there, then stuck the new one in.. is the MGW alot bigger or something?
on that plate the front screws are under the radio part of the center console
I didn't pop off my center consol to instally my MGW. For me it was a great excuse to use my new ratchety open ends at the time. A little tight but they work great.
Kevin
i had to get a small wrench in there to get mine out.. but it is do-able... dont blame me if you get cut like i did.. that little gold plate is a sharp mofo
Some Stangs you can get away with just removing the shifter bezel and boot, others are not so fortunate. I've had both.
It's been a while, but aren't there also two sheet metal screws behind the radio compartment area on the outside of the console?
Yes there is, coming in from the sides.
