Installing New engine C4 torque conv. question
  • Thread starter Thread starter spade33
  • Start date Start date Jan 31, 2009
spade33
198
Tempe, Arizona
Jan 31, 2009
  • Jan 31, 2009
my uncle has a 66 mustang fastback that he is getting ready to install the engine and transmission (c4) in and he had a question. He wanted to know if he needed to put transmission fluid into new torque converter before installing it onto the engine. If so how much would he need to pour into it?
spade33
198
Tempe, Arizona
Jan 31, 2009
  • Jan 31, 2009
nobody? he was hoping to get it in today but probably not going to happen now... he has a few books but none of them are specific on the issue
woodsnake
1,352
15
69
Hicksville, NY
Jan 31, 2009
  • Jan 31, 2009
I would recommend 1/2 to one qt. for the initial firing, and then add more as required. You only need to avoid "dry" contact. If it's a new or rebuilt, the fluid pressure will get stuff moving right smartly.
I guess TCI says "fill it!"
TCI - TECHNICAL INFORMATION: Transmission and Torque Converter Fluid Capacity
blown65
1,938
Queen Creek Arizona
Jan 31, 2009
  • Jan 31, 2009
I always put a quart in when I do it. Never do it dry thats for sure.
HookandLadder
261
St Louis
Jan 31, 2009
  • Jan 31, 2009
1 quart and check it after the fire up to add more.
spade33
198
Tempe, Arizona
Feb 2, 2009
  • Feb 2, 2009
thanks alot guys he started going ahead and puting the transmission on the engine without putting any oil in the converter. So thanks alot for giving us the heads up and lettign us know what to do!!
D
D.Hearne
11,730
south louisiana
Feb 2, 2009
  • Feb 2, 2009
It needs oil. Also make damned sure the converter us seated all the way in before trying to bolt the engine and transmission together. And if they won't slip together easily, STOP!!!!!!! Do NOT try to force them together. You WILL end up breaking the front pump gear with the converter. This has happened to more people than you'll ever guess. I would also fill the conveter halfway full. That's the most you'll get into it and not spill when it's inserted into the transmission.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
For Sale 2007 MUSTANG CONVERTIBLE/137,797 MI/ 20,000+MI NEW ENGINE/BRAND NEW TIRES/$4500 OBO/WAUKEGAN, IL
  • Savage21!
  • Sep 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Sep 10, 2026
Savage21!
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
D
Brand New C6 Transmission Pouring fluid
  • Danielperry2003
  • Jun 17, 2025
  • Other Auto Tech
Other Auto Tech Jun 17, 2025
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
